[gdal-dev] Building GDAL against custom libtiff
Juan Pedro Pérez Alcántara jp.alcantara at geographica.gs
Wed Sep 17 02:49:37 PDT 2014
Even, just wondering, maybe GRASS seems to be a good candidate for that?
Chief Science Officer
+34 670 786 422
Avda. de Grecia 8
41012 Sevilla, Spain
T  +34 954 701 157
F  +34  955 110 441
*www.geographica.gs <http://www.geographica.gs>*
On Wed, Sep 17, 2014 at 12:01 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Juan,
> It might be possible that one of the other third-party library that GDAL
> links
> to already links against your system library. Try a as minimal as possible
> GDAL build first to see if my hypothesis is right.
> Another thing to check is after configure to open GDALmake.opt. If there
> are
> occurrences of "-L/usr/lib ", remove them, and run make.
> Even
> Le mercredi 17 septembre 2014 11:36:49, Juan Pedro Pérez Alcántara a écrit
> > Hi,
> > I'm having from quiet some time now an issue when building GDAL against
> an
> > external TIFF library. For sure is a very silly thing but I'm missing
> > something important nonetheless. So long, I ended up always compiling
> with
> > --with-libtiff=internal and have a perfectly functional installation, but
> > I'm just curious about this.
> > The things goes as follows: I installed tiff-4.0.3.tar.gz from osgeo.org
> > then I try to configure the GDAL build with --with-libtiff=/usr/local/,
> > where I installed the libtiff, and it compiles. But somehow, when
> executing
> > gdalinfo against a TIFF, I get the following:
> > Warning 1: libtiff version mismatch : You're linking against libtiff 3.X,
> > but GDAL has been compiled against libtiff >= 4.0.0
> > And when I ldd gdalinfo, I get:
> >  libtiff.so.4 => /usr/lib/i386-linux-gnu/libtiff.so.4 (0xb6482000)
> >  libtiff.so.5 => /usr/local/lib/libtiff.so.5 (0xb640e000)
> > and I'm at a loss, it seems that is trying to link to the system library
> > instead the custom installed. Any insight on this will be most welcomed.
> > Many thanks in advance.
> > +34 670 786 422
> > Avda. de Grecia 8
> > T  +34 954 701 157
> > F  +34 955 110 441
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140917/dcccbbe5/attachment.html>
