[gdal-dev] Forcing gdal translate to only rotate/scale
Jesse McGraw jlmcgraw at gmail.com
Sat Sep 20 09:56:11 PDT 2014
Is it possible to force gdal_translate to only rotate/scale an image
when given a list of more than two GCPs?
I'm manually georeferencing maps which are all North-up and I'd like
to supply as many GCPs as possible to average out my errors but if I
provide more than two it will potentially skew the image.
Thanks!
-Jesse
