[gdal-dev] Binary Predicates in SQLite SQL dialect
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Sep 30 14:20:12 PDT 2014
Even Rouault <even.rouault <at> spatialys.com> writes:
> Le mardi 30 septembre 2014 20:20:14, Andre Vautour a écrit :
> > I would build SpatiaLite with GEOS support, but unfortunately its LGPL
> > licensing is too restrictive for our application. So, would it make
> > sense to change the logic in OGRSQLiteRegisterSQLFunctions to account
> > for the case of SpatiaLite being built without GEOS?
> Andre,
> That makes sense. I guess that can only be checked at runtime though,
probably
> by issuing a ST_Intersects() and checking the error code.
> I'd note that the spatial predicates in OGR geometry are also based on GEOS.
> Except OGRGeometry::Intersects() that has a simplified implementation
based on
> bounding box intersection when GEOS is not available.
>From the end user's point of view this example feels unpleasant. If
"Intersects" gives different results with OGR and SQLite dialects because of
different implementations, a somewhat clever user can handle it now by
selecting the dialect. But if selecting SQLite dialect might still lead to
use of  OGRGeometry::Intersects() depending on how Spatialite has been built
I would say that an end user can't manage the situation.
How about renaming it into "OGR_Intersects" in such case?
-Jukka Rahkonen-
