[gdal-dev] ogr2ogr OSM driver
    Even Rouault
    even.rouault at spatialys.com
    Thu Apr  2 06:51:08 PDT 2015
Le jeudi 02 avril 2015 15:13:41, Bjoern Ruff a écrit :
> Hello,
> can someone give a hint how 2 compile ogr2ogr under Windows so that it can
> work with OSM files?
> What I did was enabling lines for Sqlite and expat  in nmake.opt
> SQLITE_INC=-Ic:\c\sqlite3
> SQLITE_LIB=C:\c\sqlite3\sqlite3.lib
> EXPAT_DIR = "C:\externLibs\expat"
> EXPAT_INCLUDE = -I$(EXPAT_DIR)/lib
> EXPAT_LIB = $(EXPAT_DIR)/win32/bin/release/libexpat.lib
Bjørn,
looks ok to me. Make sure to run "nmake /f makefile.vc clean" in case you did
several builds and change configuration in-between.
If that still doesn't work, download a dev kit at http://gisinternals.com/ and
compare.
Even
> Thanks, Bjørn
http://www.spatialys.com
