[gdal-dev] Relating to GeoLocation tool of Geospatial PDF Document
Vankadara, Sunil sunil.vankadara at hexagongeospatial.com
Tue Apr 7 23:05:54 PDT 2015
Hi Jukka Rahkonen,
Thanks for the provided information.
Now I am able to see the lat/long values in the GeoLocator tool for the files created with ISO32000 option.
I have installed the Terrago tool bar and created the file with OGC_BP option and noticed that neither Adobe's GeoLocator tool nor Terrago Geolocator toll showing the coordinates.
In fact the Terrago Geolocator tool is greyed out for this OGC_BP option file.  Actually I am confused where this OGC_BP option used in creating the PDF documents? Or is it needs to used using the Terrago s/w only?
Regards
Sunil
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jukka Rahkonen
Sent: 07 April 2015 01:49:PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Relating to GeoLocation tool of Geospatial PDF Document
Vankadara, Sunil <sunil.vankadara <at> hexagongeospatial.com> writes:
> Hi Team,
> I created a PDF file with OGC_BP as GEO_ENCODING option like shown in
> the
 below command.  The below tif file’s Datum and Projection details are WGS84 /Geographic (lat/lon).
> ./gdal_translate.exe -of PDF ../../Data/input/sample256x256_1.tif
../../Data/output/sample256x256_1.pdf -co GEO_ENCODING=OGC_BP -co COMPRESS=JPEG -co
>  PRODUCER="ERDAS IMAGINE" -co CREATION_DATE=D:20150407111345+02'00'
> Looked at the created PDF file Metadata using QGIS tool and noticed
> that
it is having the same datum and projection details as like below.
> Layer Spatial Reference System
> +proj=longlat +datum=WGS84 +no_defs
> Layer Extent (layer original source projection)
> -84.5046451524118538,34.1200924180016969 :
-84.5042907999925177,34.1204467704210259
> When I tried to use the Geospatial Location tool
(Edit->Analysis->Geospatial Location Tool ) in the Adobe PDF Reader then the empty lat/long values are displaying at the right bottom of the  document.
> Am I missing anything in creating the Geospatial PDF document ? How to
confirm whether the CRS information is written into the PDF document or not?
> How GDAL PDF handles in case the given projection is not supported by
> the
driver?
Don't use the -co GEO_ENCODING=OGC_BP option alone if you want to show coordinates with standard Acrobat viewer without the TerraGo toolbar. Use the default which means ISO32000, or BOTH.
Confirm the result with gdalinfo "gdalinfo output.pdf". If source SRS is not recognized define it explicitly by using parameters -s_srs and -t_srs.
Alternatively you can just attach SRS to output with -a_srs.
-Jukka Rahkonen-
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
