[gdal-dev] Add Mercator_variant_A method?
Even Rouault
even.rouault at spatialys.com
Sun Apr 12 15:51:02 PDT 2015
Le samedi 11 avril 2015 15:19:48, Brad Hards a écrit :
> On Tue, 7 Apr 2015 07:12:20 AM Jukka Rahkonen wrote:
> > I felt that document somehow heavy to read but it appears in many places
> > that "Mercator variant A" is the primary name since October 2010. This
> > section is from page 34 (of 143)
> OK, where do I fix geopackage behaviour - in OGR general, or in geopackage
> format handler?
It depends on how you want to fix that.
If your intent if to have Mercator_variant_A preserved in the WKT after
importing it from GPKG, you will likely to have to edit several places in the
code base to avoid direct string comparisons with SRS_PT_MERCATOR_1SP as done
currently, but rather use a new
OGRSpatialReference::IsProjectionMethodAliasOf() or something like that.
Otherwise you can add a normalizing method in OGRSpatialReference
("morphFromModernEPSG" ??) and call it from the GPKG driver. In my opinion,
that would be the easiest and less risky way of fixing the issue.
I see exposing (exporting) Mercator_variant_A instead of Mercator_1SP as a
potential source of incompatibilities with other software, so if we were going
onto that road, especially using it as the new default name, we should try to
have a clear view of what is going to break outside of the GDAL world.
Although I see GeoTools added a few years ago "Mercator (variant A)" as an
alias :
https://github.com/geotools/geotools/commit/7fb010411eaf4210fb061f1f7dab6672d364830a
Not sure if that's enough to make them recognize "Mercator_variant_A" also.
Perhaps Robert as an idea about that since he was the author of that change ?
And I guess they still use Mercator_1SP as the main name when they export WKT
Apparently GvSIG also added "Mercator_(variant_A)" as an alias:
https://redmine.gvsig.net/redmine/issues/2624
Even
http://www.spatialys.com
