[gdal-dev] define netcdf time dimension
Michael Sumner mdsumner at gmail.com
Tue Apr 14 07:40:26 PDT 2015
Well, FWIW -
Here the CRS doesn't round-trip properly, partly as the PROJ.4 string in R
is not sufficient, and the date type gets recorded as raw integer (that's
ok depending what your target environment will need).  Using gdal_translate
you could augment the netcdf created here with a proper WKT version, so
maybe this is useful in a limited context.
I tried it so you might as well see the result:
library(raster)
r <- stack("swe_sub.mdl")
r
#class       : RasterStack
#dimensions  : 190, 352, 66880, 1  (nrow, ncol, ncell, nlayers)
#resolution  : 30, 30  (x, y)
#extent      : 444345.1, 454905.1, 4430445, 4436145  (xmin, xmax, ymin,
ymax)
#coord. ref. : +proj=utm +zone=13 +datum=NAD83 +units=m +no_defs
#names       : Band.1
dt0 <- seq(as.POSIXct("2014-03-01 00:00:00", tz = "UTC"), by = "1 hour",
length = nlayers(r))
r <- setZ(r, as.character(dt0))
writeRaster(r, "swe_sub.nc")
system("gdalinfo swe_sub.nc")
Warning 1: dimension #2 (easting) is not a Longitude/X dimension.
Warning 1: dimension #1 (northing) is not a Latitude/Y dimension.
Driver: netCDF/Network Common Data Format
Files: swe_sub.nc
Size is 352, 190
Coordinate System is `'
Origin = (444345.080000000016298,4436145.280000000260770)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
  easting#long_name=easting
  easting#units=meter
  layer#_FillValue=-3.4e+38
  layer#long_name=layer
  layer#max=3.695244550704956
  layer#min=0
  layer#missing_value=-3.4e+38
  layer#projection=+proj=utm +zone=13 +datum=NAD83 +units=m +no_defs
  layer#projection_format=PROJ.4
  NC_GLOBAL#Conventions=CF-1.4
  NC_GLOBAL#created_by=R, packages ncdf and raster (version 2.3-33)
  NC_GLOBAL#date=2015-04-14 04:29:01
  NETCDF_DIM_EXTRA={time}
  NETCDF_DIM_time_DEF={1,6}
  NETCDF_DIM_time_VALUES=1393632000
  northing#long_name=northing
  northing#units=meter
  time#long_name=time
  time#units=seconds since 1970-01-01 00:00:00
Corner Coordinates:
Upper Left  (  444345.080, 4436145.280)
Lower Left  (  444345.080, 4430445.280)
Upper Right (  454905.080, 4436145.280)
Lower Right (  454905.080, 4430445.280)
Center      (  449625.080, 4433295.280)
Band 1 Block=352x1 Type=Float32, ColorInterp=Undefined
  NoData Value=-3.39999999999999996e+38
  Metadata:
    _FillValue=-3.4e+38
    long_name=layer
    min=0
    NETCDF_DIM_time=1393632000
    NETCDF_VARNAME=layer
## context of the R session
sessionInfo()
R version 3.1.3 (2015-03-09)
Platform: x86_64-pc-linux-gnu (64-bit)
Running under: Ubuntu 14.04.2 LTS
locale:
 [1] LC_CTYPE=en_US.UTF-8       LC_NUMERIC=C
 [3] LC_TIME=en_US.UTF-8        LC_COLLATE=en_US.UTF-8
 [5] LC_MONETARY=en_US.UTF-8    LC_MESSAGES=en_US.UTF-8
 [7] LC_PAPER=en_US.UTF-8       LC_NAME=C
 [9] LC_ADDRESS=C               LC_TELEPHONE=C
[11] LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] raster_2.3-33 sp_1.0-17
loaded via a namespace (and not attached):
[1] grid_3.1.3      lattice_0.20-31 ncdf4_1.13      rgdal_0.9-2
On Wed, 15 Apr 2015 at 00:20 Dominik Schneider <
Dominik.Schneider at colorado.edu> wrote:
> Hi Mike - Thanks for the response and sorry this wasn’t quite clear. IDL
> data cubes are of the ENVI format and thus also have an associated ascii
> .hdr file. A dataset with 10 bands is here:
> https://dl.dropboxusercontent.com/u/5962491/IDLENVIswe.zip
> There is no time data in the .mdl file, but I know that the 4416 bands are
> hourly timesteps from 0:00 March 1 to 23:00 Aug 31
> I could do this in R but was trying to avoid it because R is always so
> frustratingly slow for these things…the gdal commandline utilities are much
> more awesome!
> iMac:~/Downloads $ gdalinfo swe.mdl
> Driver: ENVI/ENVI .hdr Labelled
> Files: swe.mdl
>        swe.hdr
> Size is 352, 190
> Coordinate System is:
> PROJCS["UTM_Zone_13N",
>     GEOGCS["GCS_North_American_1983",
>         DATUM["North_American_Datum_1983",
>             SPHEROID["GRS_1980",6378137.0,298.257222101]],
>         PRIMEM["Greenwich",0.0],
>         UNIT["Degree",0.0174532925199433]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["False_Easting",500000.0],
>     PARAMETER["False_Northing",0.0],
>     PARAMETER["Central_Meridian",-105.0],
>     PARAMETER["Scale_Factor",0.9996],
>     PARAMETER["Latitude_Of_Origin",0.0],
>     UNIT["Meter",1]]
> Image Structure Metadata:
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  444345.080, 4436145.280) (105d39' 9.74"W, 40d 4'25.45"N)
> Lower Left  (  444345.080, 4430445.280) (105d39' 7.97"W, 40d 1'20.58"N)
> Upper Right (  454905.080, 4436145.280) (105d31'43.92"W, 40d 4'27.72"N)
> Lower Right (  454905.080, 4430445.280) (105d31'42.49"W, 40d 1'22.85"N)
> Center      (  449625.080, 4433295.280) (105d35'26.03"W, 40d 2'54.21"N)
> Band 2 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 3 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 4 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 5 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 6 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 7 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 8 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 9 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 10 Block=352x1 Type=Float32, ColorInterp=Undefined
> Band 4416 Block=352x1 Type=Float32, ColorInterp=Undefined
> Dominik Schneider
> o 303.735.6296 | c 518.956.3978
> On Tue, Apr 14, 2015 at 12:07 AM, Michael Sumner <mdsumner at gmail.com>
> wrote:
>> On Tue, 14 Apr 2015 at 05:46 Dominik Schneider <
>>> Hi -
>>> I have some .mdl files from IDL with .hdr header files that I’d like to
>>> convert to netcdf.
>>> The following code produces a netcdf file with a subdataset for each
>>> band in the mdl file. Is there any way to define the bands as the time
>>> dimension, in this case 4416 hourly timesteps?
>>> Or is there another tool that can convert this?
>>> gdal_translate -of NetCDF swe.mdl swe.nc
>> Can you list the metadata printed out by gdalinfo swe.mdl?  What driver
>> is used?
>> Does that source file have time-metadata inside it each subdataset or do
>> you need to assign it?
>> Generally, the subdatasets are not considered as a time series - they are
>> more like multiple variables for the same observation (whereas a 3rd and
>> higher dimension/s are often unrolled into a multi-attributed 2D layer and
>> the time/z step is stored on each band -  it's a bit of a mix/clash of
>> worlds).
>> Can you point to and example file somewhere?  I imagine you'll need a
>> programmed solution, but it should be pretty easy with R or python or
>> similar.  If R is of interest you can try this and take your question to
>> the R community:
>> library(raster)
>> r <- stack("swe.mdl")
>> r <- setZ(r, [whatever the vector of dates should be])  ## pseudocode
>> writeRaster(r, "swe.nc")
>> That all assumes quite a lot, including available NetCDF versions and
>> packages, required structure in the output, interpretation of the data read
>> in,  - so it's just included as an indication how it might be done.
>> Cheers, Mike.
>>> Thanks
>>> Dominik​
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150414/79fdbddd/attachment-0001.html>
