[gdal-dev] Encoding EPSG:3857 (WebMercator) in GeoTIFF, and ArcGIS interoperability
xavier lhomme
lhomme.xavier at gmail.com
Wed Apr 15 09:21:51 PDT 2015
Dis you try with 102113 or 102100 instead of 3857 ? I had once to use
those code in order to be discovered as 3857 in arcgis. when i created
geotiff with gdal warp/transform.
Le 15 avr. 2015 18:16, "Even Rouault" <even.rouault at spatialys.com> a écrit :
> Hi,
> I've collected in http://trac.osgeo.org/gdal/ticket/5924 a summary of
> issues
> and findings when trying to write GeoTIFF files in EPSG:3857 in a
> "standard" way
> (using ProjectedCSTypeGeoKey = 3857), while making them correctly
> displayed by
> ArcGIS (and ideally by other independant implementations).
> The current situation is that there's no such way (AFAIK). I'd appreciate
> any
> feedback/suggestion related to that issue.
> Best regards,
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150415/4e98ae82/attachment.html>
