[gdal-dev] Setting up C++ environment with GDAL on CentOS
Dr. Joshua Jackson
josh at nside.io
Wed Apr 15 11:58:46 PDT 2015
Hey GDAL Team - I have a server running CentOS 6. I have downloaded the complete 1.11.2 source and successfully built and installed GDAL.
I am now trying to make my C++ program which uses GDAL and I’m not having any luck. I get an “unknown reference” error on all my calls to GDAL methods. (GDALAllRegister, GDALOpen, etc).
On my #include I get an error if I use #include “gdal/gdal_priv.h”; but it makes it past that point if I use #include “gdal_priv.h” alone.
I am using cmake with this project and here is my CMakeLists.txt below. I have manually set GDAL_INCLUDE_DIRS to be /usr/local/lib which is where all the libgdal*.so files are located.
cmake_minimum_required(VERSION 2.8)
project( AerialMask )
find_package( OpenCV )
find_package( GDAL )
include_directories(
${OpenCV_INCLUDE_DIRS}
${GDAL_INCLUDE_DIRS}
add_executable( AerialMask AerialMask.cpp )
target_link_libraries( AerialMask ${OpenCV_LIBS} )
Joshua Jackson, PhD
Senior ResearchEngineer
(800) 604-1822 Ext. 5109 <tel:8006041822,5109> (256) 648-5109 <tel:2566485109>
josh at nside.io <mailto:josh at nside.io> www.nSide.io
<http://www.nside.io/> 4031 Parkway Dr, Suite B, Florence, AL 35630
<http://www.linkedin.com/company/nside/> <http://twitter.com/nSide__Out>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150415/f64c071a/attachment.html>
