[gdal-dev] Encoding EPSG:3857 (WebMercator) in GeoTIFF, and ArcGIS interoperability
Andre Vautour
andre.vautour at caris.com
Wed Apr 15 12:40:21 PDT 2015
On 2015-04-15 14:59, Even Rouault wrote:
> Le mercredi 15 avril 2015 18:21:51, xavier lhomme a écrit :
>> Dis you try with 102113 or 102100 instead of 3857 ? I had once to use
>> those code in order to be discovered as 3857 in arcgis. when i created
>> geotiff with gdal warp/transform.
> Xavier,
> thanks for the hint. I've just tried it and thinks it qualifies as yet another
> not completely satisfactory solution.
> Using -a_srs EPSG:102113 effectively results in a correctly placed geotiff in
> ArcGIS (with a warning about it being in GCS_WGS_1984_Major_Auxiliary_Sphere),
> but there are several points that are not that great :
> - this is not a standard EPSG code
> - due to being > 32767, it is not encoded in ProjectedCSTypeGeoKey, which was
> one of my "requirement"
> - when read by GDAL, the expanded GeoTIFF definition isn't properly identified
> as WebMercator, consequently the proj.4 string lacks the "+nadgrids=@null"
> stuff, which makes it a non-complete datum definition and cause issues when
> reprojecting such GeoTIFF with GDAL (lack of datum transformation from/to the
> WGS84 datum of WebMercator). That could admitedly being tweaked in GDAL.
> For the record, the GeoTIFF keys written by GDAL are:
> GTModelTypeGeoKey (Short,1): ModelTypeProjected
> GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
> GTCitationGeoKey (Ascii,22): "WGS_1984_Web_Mercator"
> GeographicTypeGeoKey (Short,1): User-Defined
> GeogCitationGeoKey (Ascii,151): "GCS Name =
> GCS_WGS_1984_Major_Auxiliary_Sphere|Datum = WGS_1984_Major_Auxiliary_Sphere|
> Ellipsoid = WGS_1984_Major_Auxiliary_Sphere|Primem = Greenwich|"
> GeogGeodeticDatumGeoKey (Short,1): User-Defined
> GeogAngularUnitsGeoKey (Short,1): Angular_Degree
> GeogEllipsoidGeoKey (Short,1): User-Defined
> GeogSemiMajorAxisGeoKey (Double,1): 6378137
> GeogSemiMinorAxisGeoKey (Double,1): 6378137
> GeogPrimeMeridianLongGeoKey (Double,1): 0
> ProjectedCSTypeGeoKey (Short,1): User-Defined
> ProjectionGeoKey (Short,1): User-Defined
> ProjCoordTransGeoKey (Short,1): CT_Mercator
> ProjLinearUnitsGeoKey (Short,1): Linear_Meter
> ProjNatOriginLongGeoKey (Double,1): 0
> ProjNatOriginLatGeoKey (Double,1): 0
> ProjFalseEastingGeoKey (Double,1): 0
> ProjFalseNorthingGeoKey (Double,1): 0
> ProjScaleAtNatOriginGeoKey (Double,1): 1
> And GDAL reads that as :
> PROJCS["WGS_1984_Web_Mercator",
> GEOGCS["GCS_WGS_1984_Major_Auxiliary_Sphere",
> DATUM["WGS_1984_Major_Auxiliary_Sphere",
> SPHEROID["WGS_1984_Major_Auxiliary_Sphere",6378137,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Mercator_1SP"],
> PARAMETER["central_meridian",0],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> (not sure why it lacks the latitude_of_origin, but that's another minor
> issue)
> ArcCatalog identifies the SRS as:
> WKID: 3785 Authority: EPSG
> Projection: Mercator
> false_easting: 0.0
> false_northing: 0.0
> central_meridian: 0.0
> standard_parallel_1: 0.0
> Linear Unit: Meter (1.0)
> Geographic Coordinate System: GCS_WGS_1984_Major_Auxiliary_Sphere
> Angular Unit: Degree (0.0174532925199433)
> Prime Meridian: Greenwich (0.0)
> Datum: D_WGS_1984_Major_Auxiliary_Sphere
> Spheroid: WGS_1984_Major_Auxiliary_Sphere
> Semimajor Axis: 6378137.0
> Semiminor Axis: 6378137.0
> Inverse Flattening: 0.0
> Even
The way I see it, there are two different ways to model Google Mercator:
1. As a WGS84 datum/ellipsoid with a custom Mercator-based projection
which uses only the semi-major axis, as seems to be currently done in
EPSG: http://epsg-registry.org/export.htm?wkt=urn:ogc:def:crs:EPSG::3857
2. As the Google spheroid with Mercator 1SP and no transformation when
going to WGS 84.
I don't think #1 is currently an option given the list of coordinate
transformation codes available in the GeoTIFF specification.
For #2, I would think/hope that if you specified the identity
7-parameter transformation in the GeoTIFF header, ArcGIS would properly
reproject the image:
http://trac.osgeo.org/geotiff/ticket/26
André
