[gdal-dev] Trouble with French Ecw map
Nicolas Ragg
ragg.gdal at free.fr
Thu Apr 16 22:53:41 PDT 2015
Hello Jacek
I'm using gdal 1.11, binaries downloaded from gisinternals with the
ref 1600
gdal_translate -formats gives me that for ECW:
ECW (rov): ERDAS Compressed Wavelets (SDK 5.0)
In Qgis valmiera i have several gdal dll, so i'm not sure which one they use
And in worldwind it's a custom build, using gdal 1.7.2
Unfortunately I don't think i can share the file, I've to think of a way
to create another ecw and copying the metadata, i could not using
gdal_translate
Regards
Nicolas
On 17/04/2015 02:41, Tomaka, Jacek wrote:
> Nicolas,
> What version of ECW library are you using?
> Is there any chance I could see the file(s)?
> Regards.
> Jacek Tomaka
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Nicolas Ragg
> Sent: Friday, 17 April 2015 7:32 AM
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Trouble with French Ecw map
> On 15/04/2015 07:59, Jean-Claude Repetto wrote:
>> Please run the command : gdalinfo -mdd ECW file.ecw What are the
>> metadata (ECW) :
>> PROJ= ?
>> DATUM= ?
>> Jean-Claude
> Still looking into this problem, i've run gdalinfo with -mdd VERSION, output is :
> Metadata:
> COLORSPACE=RGB
> COMPRESSION_RATE_TARGET=10
> VERSION=2
> Looking on http://www.gdal.org/frmt_ecw.html, i may be facing backwards compatibility issue with a V2 file, something i was not expecting since V5.x ECW plugin is supposed to be backward compatible.
> Using gdal 1.7.2 i have no mdd at all, and no srs reported but somehow the map coordinates are good when importing it in Worldwind.
> Could it be related to the plugin compatibility issue related there
> https://trac.osgeo.org/gdal/ticket/4635 ?
> gdal-dev mailing list
