[gdal-dev] gdalwarp skews and rotates PDF rasters, when converting to GeoTIFF, when PDF raster are in Landscape orientation or (True north facing botton or right or left)
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Fri Apr 17 13:50:28 PDT 2015
Gane R <gane.prog <at> gmail.com> writes:
> I am using gdal 1.10.1I have a set PDFs, I am converting them to GeoTIFF.
> I am using gdal with poppler for pdf driver.
> I have PDFs of places with orientation in Landscape, and north facing
right or left or bottom.
> When I apply a gdalwarp for these PDFs I get unexpected rotation at
GeoTIFF output.
> I read this link
toohttp://lists.osgeo.org/pipermail/gdal-dev/2014-June/039438.html
> I need some guidance for this. Say some kind of work flow with gdal
command line tool will be of great help.
If you can share one of your PDF files and your gdalwarp command then
someone may get interested in trying to reproduce your problemn
-Jukka Rahkonen-
