[gdal-dev] Retreivinng a table with a condition using ogr2ogr OCI
Even Rouault
even.rouault at spatialys.com
Tue Apr 21 09:05:19 PDT 2015
Le mardi 21 avril 2015 16:43:44, Jukka Rahkonen a écrit :
> Even Rouault <even.rouault <at> spatialys.com> writes:
> > Ammar,
> > it seems that the resulting layer from the SQL query is called "SELECT *
> > FROM TABLE WHERE ....", which is a bit an unfortunate choice (other
> > drivers generally call it "result" or "sql_statement", etc...
> > Anyway, add "-nln the_layer_name_you_like" to avoid this.
> > Alternatively you can add -where "DETAILTYPE = 'Something'" in your
> > first ogr2ogr command that operates on the table, as opposed to a full
> > SQL request.
> If I read the command right:
> "ogr2ogr 3011 -f "ESRI Shapefile" OCI:"user/password <at> ... "
> it does not follow the ogr2ogr syntax as documented in
> http://www.gdal.org/ogr2ogr.html
> ogr2ogr .... dst_datasource_name src_datasource_name
Jukka,
The target filename (directory) is 3011 in the above. Although it is
recommanded to put options starting with a dash character before other
options, the parser is pretty tolerant about that.
From the statements that work and the ones that do not work, and what I saw in
the OCI driver code, I do think the issue comes from the implicit naming of a
OCI SQL resulting layer.
Even
> The command is lacking the dst_datasource name. The real bug for my mind is
> that ogr2ogr still tries to create an output. It should rather throw an
> error "No destination defined".
> Try with
> "ogr2ogr 3011 -f "ESRI Shapefile" output.shp OCI:"user/password <at>... "
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
