[gdal-dev] Data type of DATE in SpatiaLite
Even Rouault
even.rouault at spatialys.com
Tue Apr 21 14:28:34 PDT 2015
Le mardi 21 avril 2015 23:00:48, Jukka Rahkonen a écrit :
> Hi,
> After short investigation it looks that ogr2ogr is writing DATE data into
> Spatialite database by creating a field that is defined to be of type
> "DATE" and by inserting there string values in format "2006-12-21".
> This is not what current native SpatiaLite tools do. They use either text
> strings placed into TEXT field or Julian Day numbers stored into a DOUBLE
> field. Details about why in the forum thread
> https://groups.google.com/d/msg/spatialite-users/lvd7uPJ3Big/TKNPiG6IqsIJ
> From the GeoPackage specification I can read about how to store DATE:
> "ISO-8601 date string in the form YYYY-MM-DD encoded in either UTF-8 or
> UTF-16. See TEXT.
> Stored as SQLite TEXT"
> DATETIME is to be stored as SQLite TEXT as well:
> "ISO-8601 date/time string in the form YYYY-MM-DDTHH:MM:SS.SSSZ with T
> separator character and Z suffix for coordinated universal time (UTC)
> encoded in either UTF-8 or UTF-16. Stored as SQLite TEXT""
Jukka,
The GPKG spec also mentions that the declared column data type that must be
used is "DATE" (or "DATETIME"), that is the one used in the CREATE TABLE
statement : CREATE TABLE my_table ( DATE my_date, ...)
This name in SQLite can be anything, since you can store anything in a SQLite
cell. See "Type affinity" in https://www.sqlite.org/datatype3.html
On reading, the SQLite driver will currently only accept data with stored as
text (speaking here about the content of each cell, not the declared column
type!) and will try to parse them as ISO-8601. If the values are stored as
floating point or integer values, it will report null. It might be good to
implement the rule at 1.2 Date and Time Datatype of
https://www.sqlite.org/datatype3.html to convert from Julian days or Unix
time.
And AFAIR the SQLite/Spatialite driver must do something similar as you noted.
This is practical to use a specific type name rather than a generic one like
TEXT, since you can know the field type of each field.
> It might be good to uniform the behaviour and make also the
> SQLite/Spatialite driver to use a TEXT field for DATE.
> But how GDAL could
> then recognize DATE data when it reads Spatialite?
Honestly I didn't read carefully the whole thread you mention, but it seems
there's no rule imposed by Spatialite (I should rather the tools in the
Spatialite ecosystem, since Spatialite itself doesn't manage at all non-
spatial columns, as the name implies). You might have to use appropriate SQL
functions related on datetimes to transform between Julian days or ISO-8601.
Even
http://www.spatialys.com
