[gdal-dev] Processing huge DEM dataset
Paul Ramsey pramsey at cleverelephant.ca
Thu Apr 23 05:22:30 PDT 2015
I have in the past, with other tool sets, not GDAL, approached this by building out padded tiles as the first step. So for each tile, merge it with it’s neighbors, then clip out the middle so you get a somewhat larger tile. Give it a nice thick buffer.
Now all your tiles overlap. Process them all individually. Thanks to the generous overlap they should, on the boundaries, come up w/ the same answers. Once you have final results (hillshades, contours, etc) clip them to the real tile boundary. In the case of contours you may need to finally snap the ends together, but it should not be a huge snap, just a tiny one.
ATB,
P.
http://postgis.net
http://cleverelephant.ca
On April 23, 2015 at 3:01:45 AM, Marcos Dione (mdione at grulic.org.ar) wrote:
> I have SRTM's DEM 1x1 degree 30m resolution tiles for the whole Europe and I'm trying to
> generate several raster images based on
> that (elevation coloring, slopeshade and hillshade), but I'm not sure about the right
> approach to do it for that amount of data.
> The simplest approach is to stitch the DEMs and then process, but that takes ages, specially
> if I try to use uncompressed, tiled
> GeoTIFFs as output. The stitching can even be done using a virtual file, which saves space.
> If I process each tile individually, and then build a virtual file on top, I get shades
> on the edges of tiles. This shade is due
> to the tile ending and the shading algorithm assuming there's a 0 elevation point right
> to it. So, question A) is that so?
> I think that getting the shade in the output is due to the algorithm for finding a pixel
> uses the first tile that has it.
> Question B) is that so?
> If so, C) could I simply avoid this by generating another vrt file that lists each tile
> as having a bbox of only the 1x1 degree
> instead of the 1x1 degree plus an extra pixel border? If I get the time, I'll try this this
> afternoon (I just thought of it).
> All this I can do more or less with the gdal command line tools, without much programming.
> Then comes a more programmatic way:
> either use gdaldem or use the GDAL API to process each tile, then cut the 1x1 degree image
> and save that; then stitch them/build a
> vrt file on top. As you can see, this is what I've been avoiding to do :)
> Finally, I would also like to generate contour lines for this. So far I managed to generate
> them for 5x5 tiles with 90m
> resolution, then I import them in postgis. When I render them, on the edges of such tiles
> I see the lines from one crossing the
> others, looking ugly. For instance:
> http://grulicueva.homenet.org/~mdione/Elevation/#14/45.0000/15.0000
> I tried used a stitched file for the whole region but I ran out of memory with gdal_contour.
> Again, this was with 90m resolution
> tiles; now I have 30m, which means 9 times as much data. D) How could I properly process
> all that?
> Thanks in advance for any ideas,
> -- Marcos.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
