[gdal-dev] Implementing a streaming version of KML Driver
Dmitry Baryshnikov
bishop.dev at gmail.com
Tue Apr 28 14:30:56 PDT 2015
https://code.google.com/p/libkml/downloads/list?can=1&q=&colspec=Filename+Summary+Uploaded+ReleaseDate+Size+DownloadCount
The last release was on Feb 2010 - 5 year ago. Does the libkml still alive?
Also libkml has depending on boost, and kml driver has no external
depending.
Best regards,
Dmitry
29.04.2015 00:03, Yuchen Zhong пишет:
> Hello everybody,
> I notice that there are two KML drivers in GDAL, namely KMLDriver and
> LIBKMLDriver. Both of them will load all the data into memory.
> We would like to write a new KML driver for GDAL, a streaming version,
> so as to reduce memory consumption. We would still want to use LIBKML,
> so that we don't have to reinvent the wheels. However, the LIBKML only
> supports SAX API, and GDAL doesn't seems to works with that very well.
> I am wondering whether it is a good idea to go along this path.
> This is about the existing streaming parse in LIBKML (under *KmlStream
> Section*):
> https://code.google.com/p/libkml/wiki/KmlEngineReference
> Hope can hear some of your opinions about this idea.
> Sincerely,
> Yuchen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150429/19a5ed62/attachment.html>
