[gdal-dev] Regarding libkml driver
Rashad M
mohammedrashadkm at gmail.com
Sun Aug 2 12:22:56 PDT 2015
On Sun, Aug 2, 2015 at 9:05 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > No API changes. it make building and configuring libkml easier!
> > Correct me If I am wrong, I guess with a pkg-config would be easier to
> find
> > and configure libkml libs.
> Yes, that would probably be better. That said my experience with GDAL
> configure
> --with-libkml has been good up to now. But having a pkg-config script could
> simplify the current detection and configuration logic.
> Another action would be to change the documentation page of the libkml
> driver
> and related Trac wiki pages to point to your fork.
> By the way, did you try running the ogr_libkml.py tests from GDAL autotest
> suite with your fork ?
> What is the Windows status of the fork ? And with a Windows build of GDAL ?
I had tested on VS2010 on windows7 and works fine. with a gdal windows
built, I haven't tested yet. I will get back to you on that and also on
ogr_libkml.py test
> To answer your initial question, yes, changes should go as a patch to a
> Trac
> ticket.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150802/e553f722/attachment.html>
