[gdal-dev] Piping VRT to gdal_translate with /vsistdout
Luke
lukepinnerau at gmail.com
Mon Aug 3 17:20:15 PDT 2015
Hi List,
To avoid temporary files when warping to VRT and compressing with
gdal_translate, I was playing around with piping gdalwarp VRT output to
gdal_translate but couldn't get it to work on Windows (7) or Linux (Ubuntu
14.04). GDAL version is 1.11.1
The command I used was gdalwarp -q -t_srs EPSG:32611 -of vrt byte.tif
/vsistdout/ | gdal_translate -co compress=lzw /vsistdin/ byte_wgs84.tif
byte.tif is from the autotest suite -
https://svn.osgeo.org/gdal/trunk/autotest/gcore/data/byte.tif
Windows generates the following error (command was run in cmd.exe):
ERROR 1: Parse error at EOF, not all elements have been closed,
starting with Co
GDALOpen failed - 1
starting with Co
The linux error is similar with "ColorInte" instead of "Co". Command was run
in default bash shell using gnome terminal.
Redirecting /vsistdout/ to a file and running gdalinfo/gdal_translate on
that file works as expected.
Is there a way to pipe VRT between GDAL utilities?
Regards
Luke
View this message in context: http://osgeo-org.1560.x6.nabble.com/Piping-VRT-to-gdal-translate-with-vsistdout-tp5218386.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
