[gdal-dev] problem assigning EPSG:27700
Darrel Maddy
darrel.maddy at newcastle.ac.uk
Wed Aug 5 05:24:06 PDT 2015
Apologies if this is not the right place to ask this.
I use gdal to read and write datafiles for my landscape evolution model. I have been trying to get the output rasters to include the appropriate spatial referencing, in this case the OS National Grid (EPSG 27700). I used the guidance in the raster api tutorial and my code has the following line:
OSRSetWellKnownGeogCS( hSRS, "EPSG:27700" );
Alas this is clearly not recognised as nothing is written in the header i.e. using gdalinfo I just get Coordinate System is ' ' . If I substitute EPSG:4227 then the information appears - but is, of course in the wrong place!
If I use gdalsrsinfo EPSG:27700 I get the correct information.
I am clearly doing something wrong and would appreciate any suggestion.
Many thanks
Darrel
Prof Darrel Maddy
Chair of Quaternary Science
Newcastle University
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150805/a1efa0e5/attachment.html>
