[gdal-dev] how to build dwg driver?
Ivan Lucena lucena_ivan at hotmail.com
Tue Aug 11 09:48:17 PDT 2015
Hi Mark,
I am far from a Windows machine, so I can't give you much details.
After loading the sample project for VS 2010, I build the libs and then I was able to build the OGR/DWG plugin.
But when I tried to run it, I got a error message saying that a .dll was missing.
That missing .dll doesn't come with the SDK, so I am stuck at that point.
I tried with the latest SDK and with some older versions and got the same result.
I will keep you posted too.
Thanks,
Ivan
> Date: Tue, 11 Aug 2015 09:17:00 -0700
> From: myoung at pyxisinnovation.com
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] how to build dwg driver?
> Hello Ivan,
> I am running into a similar issue trying to build the DWG driver with the
> latest Teigha libraries. Did you get your issue resolved? If I learn
> anything I will post it here.
> Mark
> View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-how-to-build-dwg-driver-tp5216555p5219383.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150811/38129ee5/attachment.html>
