[gdal-dev] how to build dwg driver?
Ivan Lucena lucena_ivan at hotmail.com
Tue Aug 11 14:55:37 PDT 2015
Hi Jeff,
I usually go withe Microsoft Process Monitor but thanks for the tip.
The missing dll name is "TD_Alloc_4.0.01_10.dll" (or "TD_Alloc_3.09.1.0.dll", depending on the TX_SDK version I tried).
The question is, should that dll be created when I run the sample-project or should it be distributed pre-build with the TX_SDK zip download?
Another possibility would be to build the plugin against the static version of TD_Alloc.lib without run-time dependence on the dll.
But I don't know if that is possible either.
Regards,
Ivan
> Date: Tue, 11 Aug 2015 14:00:24 -0300
> From: jmckenna at gatewaygeomatics.com
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] how to build dwg driver?
> On 2015-08-11 1:48 PM, Ivan Lucena wrote:
> > Hi Mark,
> > I am far from a Windows machine, so I can't give you much details.
> > After loading the sample project for VS 2010, I build the libs and then
> > I was able to build the OGR/DWG plugin.
> > But when I tried to run it, I got a error message saying that a .dll was
> > missing.
> I'm in this exact situation often; I find the best thing to do is to
> download DependencyWalker (http://www.dependencywalker.com/), click on
> "depends.exe" and open "ogrinfo.exe" inside that, and look closely at
> the dll files it lists in the top left panel (hint: enable full paths by
> menu View/Full Paths).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150811/0643517c/attachment.html>
