[gdal-dev] Burn 3d-lines from python
Simon Lyngby Kokkendorff
silyko at gmail.com
Wed Aug 12 03:54:17 PDT 2015
Hi Even,
Thanks a lot for the explanation - will modify as needed! Yes, the
behviour was a little surprising, as it is not present with e.g.
'ATTRIBUTE=<something>' .
Cheers,
Simon
On Wed, Aug 12, 2015 at 11:25 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 11 août 2015 11:36:32, Simon Lyngby Kokkendorff a écrit :
> > Hello list,
> > I'm trying to rasterize some 3d-lines programtically from python. Using
> > gdal 1.11.2 from the osgeo4w64 environment. Seems to work fine, except
> that
> > I get a z-offset of 255 (one byte) in my output raster. Works fine if I
> use
> > gdal_rasterize with the -3d option.
> > The following python code should reproduce the problem:
> > from osgeo import ogr,gdal
> > print gdal.__version__
> > georef=[0,1.0,0,10.5,0,-1.0]
> > m_drv_ogr=ogr.GetDriverByName("Memory")
> > line_ds = m_drv_ogr.CreateDataSource( "dummy")
> > layer = line_ds.CreateLayer( "lines", None, ogr.wkbLineString25D)
> > layerdefn=layer.GetLayerDefn()
> > line=ogr.Geometry(ogr.wkbLineString25D)
> > line.AddPoint(0,5.5,0)
> > line.AddPoint(10,5.5,10)
> > feature=ogr.Feature(layerdefn)
> > feature.SetGeometry(line)
> > res=layer.CreateFeature(feature)
> > layer.ResetReading()
> > m_drv_gdal=gdal.GetDriverByName("MEM")
> > raster_ds=m_drv_gdal.Create("dummy",10,10,1,gdal.GDT_Float64)
> > raster_ds.SetGeoTransform(georef)
> > ok=gdal.RasterizeLayer(raster_ds,[1], layer,
> options=["BURN_VALUE_FROM=Z"])
> > A=raster_ds.ReadAsArray()
> > print A
> > Will output:
> > [[ 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.]
> > [ 255. 256. 257. 258. 259. 260. 261. 262. 263. 264.]
> > [ 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.]]
> Simon,
> looking closer, the issue is that the Python bindings of
> gdal.RasterizeLayer()
> have a default constant burn value of 255 if not explicitly specified. This
> constant burn value comes in addition to the other source of burning, such
> as
> Z.
> So the fix is to add burn_values = [0] as a keyword of
> I guess the rationale of that was that without any option, the rasterizing
> would burn 255, which is a reasonable default. But it is true that it is
> rather unexpected if you specify BURN_VALUE_FROM=Z
> Even
> > Cheers,
> > Simon Kokkendorff, Dansish Geodata Agency
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150812/8480fc46/attachment.html>
