[gdal-dev] Georeference without rotation of output image
Ivan Castellucci Vidal
ivanc.vidal at gmail.com
Fri Aug 14 08:17:34 PDT 2015
Hi, list
First of all, I searched on the list but I hadn't found anyone with the
same issue as me.
I'm working with aerial images of fields that I use as input to my program
which needs to process the images and find some visual patterns and then
give some output for the users.
I use georeferenced images because I need to extract geographic data after
my program process the image. So, when I warp my image with gdalwarp it
rotates the image and as a consequence of northing up the image, it rotates
the raster and adds 4 black triangles to make it rectangular.
The problem is, when I run my program, this "borders" are messing with my
algorithm and are a source of inaccuracy on the image processing. I can get
rid of them with more image processing but any extra step is
computationally heavy, specially when using large images.
I would need to avoid the rotation of the raster after gdalwarp is used to
implant the geotransformation on the destination image. I don't really care
if the image is not north up after warping it so I may not need gdalwarp
and instead I may be able to use some other solution based on the C API if
needed.
If it's relevant, the source images are in JPEG format and the destination
are in GeoTiff format, the transformation is done by using 3 (sometimes
more) GCPs and I'm using EPSG:4326 projection.
I didn't explained details of the pattern recognition process because I
think it's irrelevant to my problem and it will be confusing but if you
need any, just let me know.
Any help is appreciated,
Thanks in advance
Iván Castellucci Vidal
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150814/73464a62/attachment.html>
