[gdal-dev] build error
Even Rouault even.rouault at spatialys.com
Tue Aug 18 14:06:22 PDT 2015
On Tuesday 18 August 2015 11:47:07 Donovan Cameron wrote:
> I made those changes but same error.
> Tried once with,
> #define _XOPEN_SOURCE
> And a second time with,
> #define _XOPEN_SOURCE 500
What is your config: OS + gcc ?
I can't reproduce with Ubuntu 14.04 with gcc 4.8
Could you intercept the gcc command line of gdalserver.c and replace the -c -o
gdalserver.o by -E to have the preprocessor output ?
Providing the /usr/include/netdb.h of your system might also give some clue,
since it is in this file that getaddrinfo is defined.
> Donovan
> On 18/08/15 10:30 AM, Even Rouault wrote:
> > On Tuesday 18 August 2015 12:00:46 Vincent Schut wrote:
> >> Hi,
> >> this morning I wanted to refresh my gdal build, so I did an svn update
> >> (and
> >> later a fresh svn checkout to be sure), but I get an error when make
> >> wants
> >> to build gdalserver:
> > This might be related to the following that is perhaps too restrictive
> > #if defined(__STDC_VERSION__)
> > #endif
> > Could you try remonving the #if defined / #endif, so that #define
> > _XOPEN_SOURCE is defined ?
> > Perhaps you need #define _XOPEN_SOURCE 500
> > Even
http://www.spatialys.com
