[gdal-dev] build error
Vincent Schut
schut at sarvision.nl
Tue Aug 18 23:20:13 PDT 2015
On 08/19/2015 08:18 AM, Vincent Schut wrote:
> On 08/18/2015 07:30 PM, Even Rouault wrote:
>> On Tuesday 18 August 2015 12:00:46 Vincent Schut wrote:
>>> Hi,
>>> this morning I wanted to refresh my gdal build, so I did an svn update (and
>>> later a fresh svn checkout to be sure), but I get an error when make wants
>>> to build gdalserver:
>> This might be related to the following that is perhaps too restrictive
>> #if defined(__STDC_VERSION__)
>> #define _XOPEN_SOURCE
>> #endif
>> Could you try remonving the #if defined / #endif, so that #define _XOPEN_SOURCE
>> is defined ?
>> Perhaps you need #define _XOPEN_SOURCE 500
>> Even
> I tried both (with and without "500"), but it makes no difference. Any other hints?
sorry, replied before seeing the other messages. Will wait until the "600" makes it into svn.
> Best,
> Vincent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
