[gdal-dev] Fedora 20, fatal error: gdal/ogrsf_frmts.h: No such file or directory
mario60
ml at mariochiari.net
Wed Aug 19 12:51:17 PDT 2015
Himy first post.I am trying to install mysql-workbench from source on a 32
bit Fedora 22 machine.I get the following error msg:
In file included from
/root/rpmbuild/BUILD/mysql-workbench-community-6.3.4-src/backend/wbpublic/grt/spatial_handler.cpp:20:0:/root/rpmbuild/BUILD/mysql-workbench-community-6.3.4-src/backend/wbpublic/grt/spatial_handler.h:23:30:
fatal error: *gdal/ogrsf_frmts.h*: No such file or directory compilation
terminated.
Google does not help, and I am not sure what to look for.
Could you help somehow?
I appreciate
mario
[root at localhost bin]# locate
gdal/usr/bin/gdal_contour/usr/bin/gdal_grid/usr/bin/gdal_rasterize/usr/bin/gdal_translate/usr/bin/gdaladdo/usr/bin/gdalbuildvrt/usr/bin/gdaldem/usr/bin/gdalenhance/usr/bin/gdalinfo/usr/bin/gdallocationinfo/usr/bin/gdalmanage/usr/bin/gdalserver/usr/bin/gdalsrsinfo/usr/bin/gdaltindex/usr/bin/gdaltransform/usr/bin/gdalwarp/usr/lib/gdalplugins/usr/lib/libgdal.so.1/usr/lib/libgdal.so.1.18.2/usr/lib/ogdi/libgdal.so/usr/share/gdal/usr/share/aclocal/ax_lib_gdal.m4/usr/share/doc/gdal-libs/usr/share/doc/gdal-libs/COMMITERS/usr/share/doc/gdal-libs/LICENSE.TXT/usr/share/doc/gdal-libs/NEWS/usr/share/doc/gdal-libs/PROVENANCE.TXT/usr/share/doc/gdal-libs/PROVENANCE.TXT-fedora/usr/share/gdal/GDALLogoBW.svg/usr/share/gdal/GDALLogoColor.svg/usr/share/gdal/GDALLogoGS.svg/usr/share/gdal/compdcs.csv/usr/share/gdal/coordinate_axis.csv/usr/share/gdal/datum_shift.csv/usr/share/gdal/ellipsoid.csv/usr/share/gdal/epsg.wkt/usr/share/gdal/gcs.csv/usr/share/gdal/gcs.override.csv/usr/share/gdal/gdal_datum.csv/usr/share/gdal/gdalicon.png/usr/share/gdal/geoccs.csv/usr/share/gdal/gml_registry.xml/usr/share/gdal/gt_datum.csv/usr/share/gdal/gt_ellips.csv/usr/share/gdal/header.dxf/usr/share/gdal/inspire_cp_BasicPropertyUnit.gfs/usr/share/gdal/inspire_cp_CadastralBoundary.gfs/usr/share/gdal/inspire_cp_CadastralParcel.gfs/usr/share/gdal/inspire_cp_CadastralZoning.gfs/usr/share/gdal/nitf_spec.xml/usr/share/gdal/nitf_spec.xsd/usr/share/gdal/ogrvrt.xsd/usr/share/gdal/osmconf.ini/usr/share/gdal/ozi_datum.csv/usr/share/gdal/ozi_ellips.csv/usr/share/gdal/pci_datum.txt/usr/share/gdal/pci_ellips.txt/usr/share/gdal/pcs.csv/usr/share/gdal/pcs.override.csv/usr/share/gdal/prime_meridian.csv/usr/share/gdal/projop_wparm.csv/usr/share/gdal/ruian_vf_ob_v1.gfs/usr/share/gdal/ruian_vf_st_uvoh_v1.gfs/usr/share/gdal/ruian_vf_st_v1.gfs/usr/share/gdal/ruian_vf_v1.gfs/usr/share/gdal/s57agencies.csv/usr/share/gdal/s57attributes.csv/usr/share/gdal/s57attributes_aml.csv/usr/share/gdal/s57attributes_iw.csv/usr/share/gdal/s57expectedinput.csv/usr/share/gdal/s57objectclasses.csv/usr/share/gdal/s57objectclasses_aml.csv/usr/share/gdal/s57objectclasses_iw.csv/usr/share/gdal/seed_2d.dgn/usr/share/gdal/seed_3d.dgn/usr/share/gdal/stateplane.csv/usr/share/gdal/trailer.dxf/usr/share/gdal/unit_of_measure.csv/usr/share/gdal/vertcs.csv/usr/share/gdal/vertcs.override.csv/usr/share/man/man1/gdal_calc.1.gz/usr/share/man/man1/gdal_contour.1.gz/usr/share/man/man1/gdal_edit.1.gz/usr/share/man/man1/gdal_grid.1.gz/usr/share/man/man1/gdal_polygonize.1.gz/usr/share/man/man1/gdal_proximity.1.gz/usr/share/man/man1/gdal_rasterize.1.gz/usr/share/man/man1/gdal_translate.1.gz/usr/share/man/man1/gdal_utilities.1.gz/usr/share/man/man1/gdaladdo.1.gz/usr/share/man/man1/gdalbuildvrt.1.gz/usr/share/man/man1/gdalcompare.1.gz/usr/share/man/man1/gdaldem.1.gz/usr/share/man/man1/gdalinfo.1.gz/usr/share/man/man1/gdallocationinfo.1.gz/usr/share/man/man1/gdalmanage.1.gz/usr/share/man/man1/gdalmove.1.gz/usr/share/man/man1/gdalsrsinfo.1.gz/usr/share/man/man1/gdaltindex.1.gz/usr/share/man/man1/gdaltransform.1.gz/usr/share/man/man1/gdalwarp.1.gz
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fedora-20-fatal-error-gdal-ogrsf-frmts-h-No-such-file-or-directory-tp5220370.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150819/2567340a/attachment.html>
