[gdal-dev] Fedora 22, fatal error: gdal/ogrsf_frmts.h: No such file or directory
mario chiari
ml at mariochiari.net
Wed Aug 19 14:44:11 PDT 2015
Hi
Il giorno mer, 19/08/2015 alle 22.37 +0200, mario chiari ha scritto:
> Kyle
> Yes, now I see /usr/include/gdal/ogrsf_frmts.h
Still, I am not able to built.
I am not sure whether it is a issue about gdal, but maybe you know how
to fix.
Now the msg is:
>>>make[2]: *** No rule to make target '/root/linux-res
-6.3/gdal/lib/libgdal.so', needed by
'backend/wbpublic/libwbpublic.so.6.3.4'. Stop.<<<
what does it mean?
I appreciate your help
mario
ps
mysql-workbench.spec states:
# Directory where iodbc and pyodbc binaries are located. Build both
using the build_iodbc.sh script
# If using distribution provided ODBC manager lib and pyodbc, then
comment out this
%define odbc_home $HOME/linux-res-6.3/usr
%define linuxres_home $HOME/linux-res-6.3
%define vsqlite_dir $HOME/linux-res-6.3/vsqlite
%define ctemplate_dir $HOME/linux-res-6.3
%define gdal_dir $HOME/linux-res-6.3/gdal
ps
# locate libgdal.so
/usr/lib/libgdal.so
/usr/lib/libgdal.so.1
/usr/lib/libgdal.so.1.18.2
