[gdal-dev] RE : Gdal 2.0, supported raster/vector formats (RIK in particular)
Even Rouault even.rouault at spatialys.com
Fri Aug 21 14:00:48 PDT 2015
Tomas,
I confirm the issue for RIK v1 and RIK v2 datasets. RIK v3 were fine. I've filed
https://trac.osgeo.org/gdal/ticket/6078 and committed a fix for trunk and 2.0
branch to restore support for RIK v1 and v2.
Even
Le jeudi 20 août 2015 20:43:16, TomasR a écrit :
> Hi
> This made me to try a bit more and found that gdal2 works with some
> files but not with other files.
> This small file
> https://www.dropbox.com/s/5k86qh3g24wrb8r/ab-del.rik?dl=0
> gdalinfo.exe can read and give data about.
> This file
> https://www.dropbox.com/s/a2dlnvgy5ckxu5b/testkarta.rik?dl=0
> which is a bit bigger (25 MB) gdalinfo cannot read. The same for my app
> in C#.
> Yours
> Tomas
> Den 2015-08-20 kl. 13:29, skrev Even Rouault:
> > RIK should be supported in 2.0 as well as in previous versions. could
> > you share a file that no longer work?
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > -------- Message d'origine --------
> > De : TomasR <monshi2+nn at gmail.com>
> > Date :20/08/2015 11:09 (GMT+01:00)
> > À : gdal-dev at lists.osgeo.org
> > Cc :
> > Objet : [gdal-dev] Gdal 2.0, supported raster/vector formats (RIK in
> > particular)
> gdal-dev mailing list
