[gdal-dev] gdal2tile
Mike Manning
mike.manning at ewn.com.au
Sun Aug 23 21:35:53 PDT 2015
Hi guys,
I've got an interesting one - I have some GeoTIFF Files that I've converted
to EPSG:3857 from GeoStationary as follows:
# gdalwarp -tr 2000 2000 -co tfw=yes -t_srs epsg:3857 -te 10018754.17
-7361866.11 20037508.34 -0.00
/storage/sat_data/20150824/IDE00422.201508240100.tif
/storage/tmp/IDE00422.201508240100.tif
Using gdalinfo reveals the following about the newly created GeoTIFF file:
# gdalinfo IDE00422.201508240100.tif
Driver: GTiff/GeoTIFF
Files: IDE00422.201508240100.tif
Size is 5009, 3681
Coordinate System is:
PROJCS["WGS 84 / Pseudo-Mercator",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
+no_defs"],
AUTHORITY["EPSG","3857"]]
Origin = (10018754.169999999925494,0.000000000000000)
Pixel Size = (2000.000000000000000,-2000.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (10018754.170, 0.000) ( 90d 0' 0.00"E, 0d 0' 0.01"N)
Lower Left (10018754.170,-7362000.000) ( 90d 0' 0.00"E, 55d 0' 2.48"S)
Upper Right (20036754.170, 0.000) (179d59'35.61"E, 0d 0' 0.01"N)
Lower Right (20036754.170,-7362000.000) (179d59'35.61"E, 55d 0' 2.48"S)
Center (15027754.170,-3681000.000) (134d59'47.81"E, 31d22'14.91"S)
Band 1 Block=5009x1 Type=Byte, ColorInterp=Gray
It looks like the map has the correct coordinates however when I run the
gdal2tiles program it errors out:
gdal2tiles.py -k -g <api_key> IDE00422.201508240100.tif mercour
ERROR 6: EPSG PCS/GCS code 900913 not found in EPSG support files. Is this
a valid
EPSG coordinate system?
ERROR 6: No translation for an empty SRS to PROJ.4 format is known.
Generating Base Tiles:
ERROR 5: Illegal values for buffer size
File "/usr/bin/gdal2tiles.py", line 2262, in <module>
gdal2tiles.process()
File "/usr/bin/gdal2tiles.py", line 478, in process
self.generate_base_tiles()
File "/usr/bin/gdal2tiles.py", line 1276, in generate_base_tiles
dsquery.WriteRaster(wx, wy, wxsize, wysize, data,
band_list=list(range(1,self.dataBandsCount+1)))
File "/usr/lib/python2.7/dist-packages/osgeo/gdal.py", line 796, in
WriteRaster
buf_pixel_space, buf_line_space, buf_band_space )
TypeError: not a string
I'm running "GDAL 1.10.1, released 2013/08/26" on Debian Jessie. I've read
that version 1.6 had this issue as it didn't know what EPSG:3857 is but I'm
running 1.10 so it can't be that.
Cheers, Mike
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150824/5f0ef8c1/attachment.html>
