[gdal-dev] gdalbuildvrt overwrite always the vrt file
Andrea Peri aperi2007 at gmail.com
Mon Aug 24 03:34:57 PDT 2015
I try to create a vrt-datasource using this sintax:
gdalbuildvrt /path-to/dataset.vrt \
    /path-ti-tiffs/tiff_1.tif
It was correctly created.
After,
I do this other command:
    /path-ti-tiffs/tiff_2.tif
The new dataset.vrt I notice is containing the only tiff-2 file and
lost the tiff-1 file.
More probably I miss something,
infact the documention of the gdalbuildvrt report a parameter:
"-overwrite" that mean:
>Overwrite the VRT if it already exists.
So I guess , without this option, the gdalbuildvrt should append the
tiff-2 and maintain the tiff-1 or alternatively raise an exception,
but not overwrite however the file.
I understand correctly ?
Thx.
Andrea Peri
qwerty àèìòù
