[gdal-dev] Do any of the utilities (gdalwarp, gdal_translate) allow for assigment of ColorInterp?
Even Rouault
even.rouault at spatialys.com
Fri Aug 28 13:54:42 PDT 2015
On Friday 28 August 2015 20:02:38 Ethan Alpert wrote:
> I'm running in to a problem with gdalbuildvrt.
> I started getting the following error from gdalbuildvrt.
> Warning 6: gdalbuildvrt does not support heterogenous band characteristics.
> Skipping ....
> I'm using 1.10
> I've isolated the problem to some of my files in DTED2 format have the
> following:
> Band 1 Block=1x3601 Type=Int16, ColorInterp=Undefined
> The other data in my build VRT looks like:
> Band 1 Block=1201x6 Type=Int16, ColorInterp=Gray
> To fix this I translated the DTED2 to VRT's and manually inserted
> <ColorInterp>Gray</ColorInterp> to the VRTRasterBand.
> I need a better way to do this. Any ideas?
Yep
1) Remove the test at line 706 of gdalbuildvrt.cpp:
pasBandProperties[j].colorInterpretation !=
GDALGetRasterColorInterpretation(hRasterBand) ||
2) Or for each some.dt2, creates a some.dt2.aux.xml file with following
content:
<PAMDataset>
<PAMRasterBand band="1">
</PAMRasterBand>
</PAMDataset>
which will override the default color interpretation
3) Or modify the DTED driver to report gray
> This electronic communication and any attachments may contain confidential
> and proprietary information of DigitalGlobe, Inc. If you are not the
> intended recipient, or an agent or employee responsible for delivering this
> communication to the intended recipient, or if you have received this
> communication in error, please do not print, copy, retransmit, disseminate
> or otherwise use the information. Please indicate to the sender that you
> have received this communication in error, and delete the copy you
> received.
> DigitalGlobe reserves the right to monitor any electronic communication sent
> or received by its employees, agents or representatives.
http://www.spatialys.com
