[gdal-dev] NSIF with GDAL
Bar Ori Ori.Bar at elbitsystems.com
Mon Aug 31 01:34:25 PDT 2015
Hello,
I have a purpose to create a file in format of NSIF.
As far as understood, I need to use the NITF driver and set the metadata which is relevant to NSIF.
I tried to work with GDAL to make it, but noticed that the metadata is saved on a "aux.xml" file.
When I remove this file or when set the GDAL_PAM_ENABLED as NO, so I lose all metadata I set (return to default or deleted).
My goal is to create one file (.nsf) containing all the relevant metadata.
My question is whether it is possible to create one file as I want. In case that yes, how to do it?
P.S. I am using GDAL in C#
Hope for a for a quick response.
Thanks,
Ori Bar | Software Developer
T +972-9-8898900 | M +972-504-734296
@ Ori.Bar at Elbitsystems.com<mailto:Ori.Bar at Elbitsystems.com>
[Description: Description: Logo]
The information in this e-mail transmission contains proprietary and business
sensitive information.  Unauthorized interception of this e-mail may constitute
a violation of law. If you are not the intended recipient, you are hereby
notified that any review, dissemination, distribution or duplication of this
communication is strictly prohibited. You are also asked to contact the sender
by reply email and immediately destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150831/8e87ea92/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150831/8e87ea92/attachment-0001.png>
