[gdal-dev] Insert data into MSSQL layer fails with OGR version 2.x
Martin Icking martin.icking at bentley.com
Fri Dec 4 01:02:22 PST 2015
Tried to copy data from a shapefile into an MSSQL layer with ogr2ogr using
the following command:
ogr2ogr -f MSSQLSpatial MSSQL:server=.;database=SpatialTest -overwrite
mydata.shp
this works fine with OGR version 1.11.x but using the newest version 2.0.1
nothing gets inserted and I get the following error message:
ERROR 1: INSERT command for new feature failed.
ERROR 1: Unable to write feature 0 from layer mydata.
ERROR 1: Terminating translation prematurely after failed
translation of layer mydata (use -skipfailures to skip errors)
Do I need additional options to successfully use MSSQL as a target in
version 2.0.1?
Tx
Martin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Insert-data-into-MSSQL-layer-fails-with-OGR-version-2-x-tp5239986.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
