[gdal-dev] gdalwarp'ing a .tif that streches from 177°9'33.13?="E to =?utf-8?q?172°21' 1.59"W (across anti-meridian)
Even Rouault
even.rouault at spatialys.com
Thu Dec 17 12:10:17 PST 2015
Le jeudi 17 décembre 2015 20:53:48, Jan Knepper a écrit :
> All,
> Having an issue getting a particular .tif file to cooperate:
> Files:
> https://www.janknepper.com/aeronav/Western%20Aleutian%20Islands%20East%20SE
> C%2048.tif
> EC%2048.tfw
> Trying:
> gdalwarp -wm 4096 "Western Aleutian Islands East SEC 48.tif" -t_srs
> WGS84 -overwrite "WGS84_Western Aleutian Islands East SEC 48.tif"
> Creates an output file that is stretched across the world...
> There are no problems with other .tif files processed.
> (Cutting it with a shapefile (.json) works fine!)
> Have searched around quite a bit, but have not found a solution for this
> problem.
> GDAL 1.11.2, released 2015/02/10
> Any help/assistance would be appreciated!
Add "--config CENTER_LONG 180" to your gdalwarp command line.
http://www.spatialys.com
