[gdal-dev] epsg code for wgs84
Brad Hards bradh at frogmouth.net
Wed Dec 23 19:11:39 PST 2015
On Wed, 23 Dec 2015 02:34:07 PM Sebastiaan Couwenberg wrote:
> On 23-12-15 14:27, Gane R wrote:
> > can any one specify the epsg code for wgs 84
> EPSG:4326, you can find this on the Spatial Reference website for
> example: http://spatialreference.org/ref/epsg/wgs-84/
This is almost certainly what you are looking for, but consider that WGS-84 is
the ellipsoid shape, not the projection. So UTM is now a Transverse Mercator
projection of the WGS-84 ellipsoid.
There are other EPSG codes that are also for WGS 84. For example:
http://spatialreference.org/ref/epsg/wgs-84-3/ for the 3D equivalent of 4326.
Brad
