[gdal-dev] subclassing CPLODBCStatement and CPLODBCSession for DB2
Even Rouault
even.rouault at spatialys.com
Mon Dec 28 10:02:27 PST 2015
Le mardi 22 décembre 2015 22:28:12, David Adler a écrit :
> I am subclassing these classes to provide additional support for DB2.
> It would simplify matters if some of the members of the parent classes
> were protected rather than private.
> The current CPLODBCStatement::Failed method is private but would be
> useful as public.
Perhaps would it make more sense to add what you need in CPLODBCStatement
itself ? (difficult to tell with what you mentionned)
> There is also a peculiarity in CPLODBCSession::Failed that it ends up
> resetting m_szLastError when RollbackTransaction is invoked so
> GetLastError doesn't usually return anything useful about the actual
> failing statement.
> Is this something that would be worthwhile opening a ticket for?
Yes likely.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
