[gdal-dev] Can not connect to MSSQL database on Azure
Paul Meems
bontepaarden at gmail.com
Tue Dec 29 01:06:05 PST 2015
Thanks Tamas,
You are completely right. We misinterpret de code.
Thanks to the link you provided we now understand we need to use a
different connection string:
MSSQL:server=***;database=***;trusted_connection=no;uid=***;pwd=***
Thanks,
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
Download the latest MapWinGIS mapping engine.
<https://mapwingis.codeplex.com/releases>
Download the latest MapWindow 5 open source desktop application.
<https://mapwindow5.codeplex.com/releases>
2015-12-28 22:18 GMT+01:00 Tamas Szekeres <szekerest at gmail.com>:
> Hi Paul,
> I don't think we are hard coding trusted_connection in the MSSQL
> connection strings. The UID and PWD is also accepted in the ODBC connection
> strings according to:
> https://msdn.microsoft.com/en-us/library/ms130822.aspx
> Best regards,
> Tamas
> 2015-12-28 22:05 GMT+01:00 Paul Meems <bontepaarden at gmail.com>:
>> I'm trying to connect to a MSSQL database on Azure using a SQL Server
>> user account but I get this from GDAL (v2): Unable to initialize
>> connection to the server for MSSQL:server=***;database=***;user=***
>> ;password=*** [SQL Server]Login failed. The login is from an untrusted
>> domain and cannot be used with Windows authentication.
>> A co-worker looked at the code of the MSSQL driver and noticed you
>> are using the ODBC drivers, but are hard coding the trusted_connection
>> parameter to be yes.
>> Is this by design?
>> Should I file a issue report?
>> Thanks,
>> Paul
>> *Paul Meems *
>> www.mapwindow.org
>> www.mapwindow.nl
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151229/b66920d9/attachment-0001.html>
