[gdal-dev] RawRasterBand and rotated images ?
Even Rouault
even.rouault at spatialys.com
Mon Feb 2 04:26:12 PST 2015
Le lundi 02 février 2015 13:01:08, Andrew C Aitchison a écrit :
> I'm preparing to write a readonly driver for a file format where the image
> is an array of bytes, so the RawRasterBand helper class seems appropriate.
> However the image data starts at the bottom left and each scanline goes
> up; viewing the data in the conventional (for gdal) manner gives west at
> the top.
Andrew,
This reminds me of how data is organized in the DTED format. The DTED format
exposes blocks of width = 1 and height = raster_height (so column
organization).
> I see two possible ways around this with RawRasterBand:
> 1) apply a rotation in the geotransform matrix; or
> 2) abuse the pixel and line offsets to rotate the data on the fly,
> so that we actually read the pixel values in the standard order
> but successive memory accesses are a row apart
> (I see that ctable2dataset.cpp, gtxdataset.cpp and
> loslasdataset.cpp use a similar trick to reflect on the fly
> but don't see any "raw" drivers that rotate).
> The files are small; less than a megabyte and under 1000x1000 pixels.
> Both methods risk making a mess of any memory caching, but one passes the
> problem up to the application and two passes it down to the RawRasterBand
> implementation.
> Does anyone have advice on whether either of these is OK,
> or should I write the driver without the RawRasterBand helper class ?
If you use RawRasterBand with appropriate pixel and line offsets value, for
each line, the whole file will be read. So you will end up reading 1 GB for a
1000x1000 images. This might be slow.
So if you don't want to use the RawRasterBand approach, you could :
- use the DTED approach with column-shaped blocks. This minimizes the memory
consumption but is a bit inefficient when processing line by line, although that
the GDAL cache block will minimize the inefficiency
- or reserve an array for the full raster and fill it at the first pixel access,
by doing reorganization from column to lines. And then you can expose line-
shaped blocks efficiently
Even
> Thanks,
> Andrew C Aitchison
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
