[gdal-dev] Can we combine all layers of kml into single GeoJSON
Manikanta Kondeti
mani.iiit123 at gmail.com
Thu Feb 5 04:25:21 PST 2015
Yeah that ll be pretty awesome :D
On Thu, Feb 5, 2015 at 4:49 PM, Jukka Rahkonen <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Even Rouault <even.rouault <at> spatialys.com> writes:
> > Mani,
> > you could use a VRT union layer to merge all layers into a single one.
> This is
> > documented at http://gdal.org/drv_vrt.html
> > In your case this would be creating a .vrt file like :
> > <OGRVRTDataSource>
> > <OGRVRTUnionLayer name="unionLayer">
> > <OGRVRTLayer name="source1">
> > <SrcDataSource>source.kml</SrcDataSource>
> > <SrcLayer>name_of_first_kml_layer</SrcLayer>
> > </OGRVRTLayer>
> > <OGRVRTLayer name="source2">
> > <SrcLayer>name_of_second_kml_layer</SrcLayer>
> > </OGRVRTLayer>
> > </OGRVRTUnionLayer>
> > </OGRVRTDataSource>
> > and then use ogr2ogr to convert this .vrt into geojson.
> Hi,
> Just thinking, but wouldn't it be nice to have "ogrbuildvrt" tool that
> would
> take list of OGR supported layers and outputs a simple vrt with one union
> layer like the one in your example?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/83620b31/attachment-0001.html>
