[gdal-dev] gdalwarp -crop_to_cutline produces non-square pixels for EPSG:3857 (GDAL 1.10.1, released 2013/08/26)
Even Rouault
even.rouault at spatialys.com
Thu Feb 5 08:50:21 PST 2015
Le jeudi 05 février 2015 17:41:22, Jesse McGraw a écrit :
> Thanks Even.
> I did try re-warping the cropped output to 3857 again and it does produce
> square pixels but at the expense of an additional warping operation
> I'm just curious why the warping that is part of the -crop_to_cutline
> process is changing the pixel ratio while a regular, non-cropping warping
> makes them square
I think I explained it in my previous answer. This is because -crop_to_cutline
uses -te internally, which in the general case doesn't allow pixel squares.
And non-cropping warping doesn't necessarily preserve extent of the output to
be the same as extent of the input (even in non-reprojection cases). You can
check that actually by comparing gdalinfo on the temporary and final datasets.
There's no fundamental reason why -crop_to_cutline couldn't produce exact
square pixels, if people are annoyed by that behaviour. Just someone has to do
it...
> On Thu, Feb 5, 2015 at 11:36 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Le jeudi 05 février 2015 17:23:06, Jesse McGraw a écrit :
> > > I'm not sure whether this is a real issue or not but I thought I'd
> > > bring
> > it
> > > up, at the very least I'll learn something
> > > When using "gdalwarp -cutline <shapefile> -crop_to_cutline" on an input
> > > raster that is in EPSG:3857 with square-pixels the output raster, while
> > > still EPSG:3857, now has non-square pixels.
> > > They're aren't terribly non-square but aren't they supposed to be
> > > completely square for EPSG:3857?
> > Perhaps... Actually the effet of -crop_to_cutline is exactly the same as
> > manually passing the target extents with -te with the bounding box of the
> > cutline.
> > It is not possible to both preserve the extent extents and pixel size at
> > the
> > same time, due to width and height being integer values.
> > So, in order to preserve pixel square, the extent should be modified a
> > little
> > bit. What is more appropriate is a matter of point of view I think.
> > You can always re-run "gdalwarp tmp.tif out.tif" where tmp.tif is the
> > output
> > of first gdalwarp with -crop_to_cutline. And you should get square pixels
> > I believe.
> > > (FWIW, I see that there are tickets opened that reference similar
> > > issues but they reference the output being shifted or the origin
> > > changing, not
> > the
> > > pixel shape changing)
> > > For example:
> > > #Warp our original .tif to EPSG:3857
> > > $gdalwarp \
> > > -t_srs EPSG:3857 \
> > > -dstalpha \
> > > -co TILED=YES \
> > > "ENR_L33.tif" \
> > > "./2.tif"
> > > #See that the output pixels are square
> > > $gdalinfo 2.tif
> > > Origin = (-8577554.996301921084523,5421778.172851986251771)
> > > Pixel Size = (43.677179501975118,-43.677179501975118)
> > > #Now crop the image to a cutline
> > > $gdalwarp \
> > > -crop_to_cutline \
> > > -dstalpha \
> > > -cutline "./ENR_L33.shp" \
> > > -cblend 10 \
> > > -co TILED=YES \
> > > "./2.tif" \
> > > "./3.tif"
> > > #See that output pixels are not square
> > > $ gdalinfo 3.tif
> > > Origin = (-8480047.445924906060100,5366376.137789577245712)
> > > Pixel Size = (43.678439570399853,-43.675457269061347)
> > > I ran some more tests and without the -crop_to_cutline option the
> > > output pixels remain square
> > > Thanks,
> > > Jesse
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
