[gdal-dev] Are those 2 things possible using gdal2tiles?
Jorge Arévalo jorge at cartodb.com
Thu Feb 5 10:15:41 PST 2015
- Generate JPEG tiles instead of PNG. Tried just replacing the driver's
name (PNG) with JPEG. Didn't work. Base tiles are generated, but
overview tiles are not. Getting this error instead: ERROR 1: Buffer too
small
- Apply a color to nodata value of generated tiles. Tried passing -a
"200,0,0" to gdal2tiles, but it was ignored.
Log file, with GDAL_DEBUG=On, where you can see the first problem
(buffer too small):
https://dl.dropboxusercontent.com/u/6599273/errors/gdal/gdal2tiles_error.log
Modified version of gdal2tiles, to generate xyz caches instead of tms
ones:
https://dl.dropboxusercontent.com/u/6599273/errors/gdal/gdal2tiles_modified.py
tif tile for testing (same error with other ones):
https://dl.dropboxusercontent.com/u/6599273/gis_data/katrina.tif
Many thanks!
Jorge Arévalo
CartoDB
http://cartodb.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/1a8e4504/attachment.html>
