[gdal-dev] Are those 2 things possible using gdal2tiles?
Jorge Arévalo
jorge at cartodb.com
Thu Feb 5 10:33:55 PST 2015
Wow, we answered at same time. So, I'll include my findings here
> Even Rouault <mailto:even.rouault at spatialys.com>
> February 5, 2015 at 7:30 PM
> Jorge,
>> - Generate JPEG tiles instead of PNG. Tried just replacing the driver's
>> name (PNG) with JPEG. Didn't work. Base tiles are generated, but
>> overview tiles are not. Getting this error instead: ERROR 1: Buffer too
>> small
> This messages comes from the WriteRaster() Python bindings, when it is passed
> a buffer that isn't large enough regarding the advertized buffer dimensions.
> Perhaps due to the fact that JPEG only supports 3 bands and PNG 4, although
> this is just a guess without deeper inspection.
The problem is in swig/python/extensions/gdal_wrap.cpp, method
GDALDatasetShadow_WriteRaster, because Buf len = 196608, min buffer size
= 262144.
Is there any method to pass a bigger buffer to JPEG driver? Or just
avoid the 4th band of PNG
>> - Apply a color to nodata value of generated tiles. Tried passing -a
>> "200,0,0" to gdal2tiles, but it was ignored.
> The doc of -a suggests that it only applies to the input dataset, not the
> output
Mmmm... ok. Is there a Python method to specify a color for nodata
pixels when creating an output dataset?
Thanks again, Even!
> Even
> Jorge Arévalo <mailto:jorge at cartodb.com>
> February 5, 2015 at 7:15 PM
> driver's name (PNG) with JPEG. Didn't work. Base tiles are generated,
> but overview tiles are not. Getting this error instead: ERROR 1:
> Buffer too small
> Log file, with GDAL_DEBUG=On, where you can see the first problem
> (buffer too small):
> https://dl.dropboxusercontent.com/u/6599273/errors/gdal/gdal2tiles_error.log
> Modified version of gdal2tiles, to generate xyz caches instead of tms
> ones:
> https://dl.dropboxusercontent.com/u/6599273/errors/gdal/gdal2tiles_modified.py
> tif tile for testing (same error with other ones):
> https://dl.dropboxusercontent.com/u/6599273/gis_data/katrina.tif
> Many thanks!
Sent with Postbox <http://www.getpostbox.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/db6f7d2c/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/db6f7d2c/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/db6f7d2c/attachment-0001.jpg>
