[gdal-dev] Tags missing on GitHub mirror
Even Rouault even.rouault at spatialys.com
Thu Feb 5 14:26:17 PST 2015
Le jeudi 05 février 2015 23:18:30, Leif Gruenwoldt a écrit :
> I happened to be playing around with this more today and I'm fairly certain
> this isn't just a GitHub UI thing. I'm betting it's svn migration related.
> After cloning a copy of the git repo I noticed the tags don't appear as
> normal tags even from the command line.
> $ git clone  https://github.com/OSGeo/gdal.git
> $ git tag
> Returns nothing, but I would expect to see the list of all tags.
> $ git branch -r | grep 1.4.1
> origin/tags/1.4.1
> Ok so the "tag" for the 1.4.1 release as well as all other tags are showing
> up as remote branches, weird.
> $ git checkout 1.4.1
> error: pathspec '1.4.1' did not match any file(s) known to git.
> That's what I expected, it doesn't see it as a normal tag, I wonder if I
> can check it out with the remote branch name.
> $ git checkout origin/tags/1.4.1
> Yup!
> $ git rev-parse HEAD
> 184230238828f0f31aed7335e4c8443963437b66
The firefox thing was just a UI problem. It seems that tags are created as git
branches and not as git tags and the name is "tags/1.4.1". Must come from the
git-svn import configuration used. Looking at mapserver, I don't see a similar
issue, so yes must be something with how git-svn was configured. Something to
perhaps reconsider if we officially transition to git some day.
> So at least I can work around this and checkout the tag using the remote
> branch name instead. The SHA1 matches up with what I was expecting so
> that's comforting. Something is definitely fishy though with the tags. I've
> migrated CVS -> git but never svn -> git so I'm not sure if this is a known
> issue.
> On Mon Oct 06 2014 at 1:20:35 PM Leif Gruenwoldt <leifer at gmail.com> wrote:
> > Oh weird.
> > I decided to go ahead and clone the gdal repo locally, but I don't see
> > the tags there either. Maybe it's something to do with the svn -> git
> > migration...
> > Worst case I will use the git SHA1
> > (184230238828f0f31aed7335e4c8443963437b66) from the 1.4.1 github URL
> > you shared for configuring my git submodule.
> > On Mon, Oct 6, 2014 at 12:20 PM, Even Rouault
> > <even.rouault at spatialys.com> wrote:
> > > Le lundi 06 octobre 2014 18:08:22, Leif Gruenwoldt a écrit :
> > >> I'm trying to add the gdal repo as a git submodule to one
> > >> of my projects. My project requires a specific older revision of gdal
> > >> (1.4.1) so I want to set the git submodule to that point in time, but
> > it's
> > >> hard to do that without the tags in the GitHub mirror.
> > >> Can someone push the git tags to the gdal github mirror?
> > > It is already there (but it seems there's a UI problem with the github
> > with
> > > Firefox, at least my version. had to use Chrome to display
> > > branches/tags)
> > > https://github.com/OSGeo/gdal/tree/tags/1.4.1
> > >> Cheers
> > >> _______________________________________________
> > >> gdal-dev mailing list
> > >> gdal-dev at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
