[gdal-dev] GDAL 1.11.0 and Cosmo-skymed L1A imagery
Even Rouault even.rouault at spatialys.com
Fri Feb 6 03:48:57 PST 2015
Le vendredi 06 février 2015 12:32:22, vf a écrit :
> Thank you for the reply, Even
> I agree that the patch was firstly to handle correctly dimensions of h5
> files : previously it was [width, height, 2] -> nbBands = width. Using
> patch, dimensions were correctly interpreted. However, the patch contained
> the following code to handle complex data type (see below). Am I
> misunderstand something ?
Hum, looking at
http://trac.osgeo.org/gdal/attachment/ticket/4227/hdf5imagedataset.patch
http://trac.osgeo.org/gdal/attachment/ticket/4227/patchCSK-L1A.diff
http://trac.osgeo.org/gdal/attachment/ticket/4227/hdf5imagedataset.cpp
I can't see the code snippets you mention below... I'm surely missing
something...
> If I would like to contribute, should I submit a patch to the tracker or
> someting else to do ...
That's the best way yes.
> /*                            GetDataType()                             */
> /*      Transform HDF5 datatype to GDAL datatype                        */
>  * Retrieves data type taking to account that file can be CSK Product with
>  * complex data
> GDALDataType HDF5ImageDataset::GetDataType(hid_t TypeID)
>     GDALDataType dataType = HDF5Dataset::GetDataType(TypeID);
>     if (iSubdatasetType == CSK_PRODUCT)
>         // if has 3 dimensions -> complex imagery
>         if (ndims == 3)
>             if( dataType == GDT_Int16 )
>                 return GDT_CInt16;
>             else if( dataType == GDT_Int32 )
>                 return GDT_CInt32;
>             else if( dataType == GDT_Float32 )
>                 return GDT_CFloat32;
>             else if( dataType == GDT_Float64 )
>                 return GDT_CFloat64;
>     return dataType;
> /*                          GetDataTypeName()                           */
> /*      Return the human readable name of data type                     */
>  * Retrieves data type name taking to account that file can be CSK Product
> with
>  * complex data
> const char *HDF5ImageDataset::GetDataTypeName(hid_t TypeID)
>         if (ndims == 3)
>                 return "Complex 16-bit integer";
>                 return "Complex 32-bit integer";
>                 return "Complex 32-bit floating-point";
>                 return "Complex 64-bit floating-point";
>     const char * name = HDF5Dataset::GetDataTypeName( TypeID );
>     return name;
> http://osgeo-org.1560.x6.nabble.com/GDAL-1-11-0-and-Cosmo-skymed-L1A-image
> ry-tp5185900p5185945.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
