[gdal-dev] Hidden regression in GDAL 1.11.0 - gdal_rasterize with postgis silently fails to render many polygons.
Graeme B. Bell
grb at skogoglandskap.no
Mon Feb 9 10:30:44 PST 2015
Excellent work Even.
Thank you very much for your kind and speedy help with this! :-)
Hoping to see it in 1.11.2, as we prefer to take RPMS from the main repos for our builds here rather than rolling our own.
For the local workaround I have removed the tables flag for the moment and will accept the speed penalty.
Graeme.
On 09 Feb 2015, at 19:23, Even Rouault <even.rouault at spatialys.com> wrote:
> Graeme,
> I confirm. This is the result of a subtile interaction of tables= , SQL request
> and SRS resolving. The PG driver has become quite subtile...
> Traced in http://trac.osgeo.org/gdal/ticket/5837 and now fixed.
> As a workaround you could use a view that does the the "select * from
> world_diamonds where st_intersects(wkb_geometry,
> ST_GeometryFromText('POLYGON((-180 -90,-180 90,180 90,180 -90,-180
> -90))',4326))" and use the view name with the -l parameter of gdal_rasterize
> (he bug doesn't occur if using a straight layer name)
> gdal_rasterize could/should be improved as well to set a spatial filter
> automatically. That way you could just use the layer name.
> Anyway I guess this will be a good reason to issue a 1.11.2RC2 with the fix.
> Even
