[gdal-dev] cmake4gdal?
Even Rouault
even.rouault at spatialys.com
Mon Feb 9 15:48:21 PST 2015
Le mardi 10 février 2015 00:34:44, Scott Bailey a écrit :
> Dmitry,
> Great! So which drivers need CMake help?
> And what is the probability of cmake4gdal replacing autotools?
Scott,
I can imagine that replacing will take a few versions until we are confident
that the cmake build system is stable enough & embrace all possibilities of
autotools & windows build systems. In the meantime, there would be coexistence
of the build systems.
Even
> SB
> On Mon, Feb 9, 2015 at 1:53 PM, Dmitriy Baryshnikov <bishop.dev at gmail.com>
> wrote:
> > Hi Scott,
> > The latest code is here:
> > 1) https://github.com/nextgis/gdal_svn/tree/cmake4gdal
> > 2) https://github.com/nextgis/gdal_svn/tree/rsmd-reader-dev <-- this my
> > current branch
> > 3) https://github.com/nextgis/gdal_svn/tree/wms-ags-dev
> > There are some problems:
> > there is no autotest directory in current repo, but it'll be more
> > correctly to have the whole fork, not only sources (CTest?).
> > So I plan to merge this three branches and make the full fork (with
> > autotest) of OSGeo/GDAL in github.
> > Anyhow we need to complete all drivers which is not yet cmaked.
> > I plan to create wiki page in new repo with table of all GDAL drivers and
> > their cmaking status and total percent.
> > By now we need:
> > 1) More testing and fixing on all platforms
> > 2) Cmaked all drivers and applications, which is not yet cmaked
> > 3) I plan to play with third party libs by cmake mechanism -
> > ExternalProject_Add
> > As for me the 2) is more important.
> > Best regards,
> > Dmitry
> > 09.02.2015 22:02, Scott Bailey пишет:
> > Building GDAL for Linux is a snap, MSVS is OK, but I find myself
> > struggling to get a compilation with MINGW.
> > I've cloned the cmake4gdal 1.9 git repo and built that in Linux. As
> > expected it was simple. Haven't had time to play with MINGW, yet.
> > Never-the-less, I've found CMake based projects less frustrating than
> > autotools when building with Windows, especially when using MINGW.
> > What is the status of cmake4gdal? Is there something I should do to
> > help?
> > Scott Bailey
> > gdal-dev mailing
> > listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal
> > -dev
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
