[gdal-dev] Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'
DeTracey, Brendan
Brendan.DeTracey at dfo-mpo.gc.ca
Wed Feb 11 05:01:30 PST 2015
I found the problem, and wanted to my idiot mistake archived for posterity. The CoordinateTransformation_TransformPoint error is thrown when a raster has no projection. I was working with a raster that I had created myself from vectors. I finally tried another sample raster and it worked. I am new to this, so my advice to other newbs is that if your product is not working try another known sample before posting questions. And always always always run ogrinfo/gdalinfo on your product to make sure nothing is missing. Once I ran gdalinfo on my geotiff and saw that:
Coordinate System is `'
I knew I had made a newbie mistake. Exported my source SRS as WKT and set as my raster projection. Problem solved.
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> bounces at lists.osgeo.org] On Behalf Of Kyle Shannon
> Sent: February-10-15 2:46 PM
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Wrong number or type of arguments for overloaded
> Brendan,
> On 02/10/2015 11:13 AM, DeTracey, Brendan wrote:
> > The should be on the path. (Very strange that the Anaconda installer
> > dumped a copy in its root directory.)
> > C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>echo %PATH%
> C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\
> Sys
> > tem32\WindowsPowerShell\v1.0\;C:\Program
> > Files\MATLAB\R2012a\bin;C:\Program Files
> (x86)\MATLAB\R2010bSP1\bin;C:\Users\DeTraceyB\AppData\Local\Continuum
> > Anaconda;C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\Scripts;
> > C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>dir proj.*
> > Volume in drive C is OSDisk
> > Volume Serial Number is 7A59-3F7E
> > Directory of C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda
> > 06/02/2015 07:45 AM 369,152 proj.dll
> > 06/02/2015 07:45 AM 19,456 proj.exe
> > 2 File(s) 388,608 bytes
> > 0 Dir(s) 76,317,147,136 bytes free
> > C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>proj.exe
> > Rel. 4.8.0, 6 March 2012
> > usage: proj.exe [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files
> > I also tried adding to the script :
> > gdal.SetConfigOption('PROJSO',
> > 'C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\proj.dll')
> > This also did not work.
> >> From: Even Rouault [mailto:even.rouault at spatialys.com]
> >> Sent: February-10-15 11:55 AM
> >> Cc: DeTracey, Brendan
> >> Le mardi 10 février 2015 16:27:54, DeTracey, Brendan a écrit :
> >>> Hi,
> >>> I am using the GDAL python bindings via Windows 64 bit Anaconda, but
> >>> I am getting an error when I try to run one of the GDAL sample
> >>> scripts, tolatlong.py e.g.
> >>> E:\parse_cis>python tolatlong.py 0 0 temp.tif Traceback (most recent
> >>> call last):
> >>> File "tolatlong.py", line 106, in <module>
> >>> (int, lat, height) = ct.TransformPoint(X, Y)
> >>> File
> >>> "C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\lib\site-packag
> >>> es \osg eo\osr.py", line 757, in TransformPoint return
> >>> _osr.CoordinateTransformation_TransformPoint(self, *args)
> >>> NotImplementedError: Wrong number or type of arguments for
> >>> overloaded function 'CoordinateTransformation_TransformPoint'.
> >>> Possible C/C++ prototypes are:
> >>> OSRCoordinateTransformationShadow::TransformPoint(double [3])
> >>> [3],double,double,double)
> >>> When I google this error I find it might be related to GDAL not
> >>> finding Proj (https://github.com/avalentino/gsdview/issues/89).
> >>> Could someone please verify that this would be the source of this
> >>> error? I have installed Proj under Anaconda and am trying to rule
> >>> out whether it is a problem with Anaconda or GDAL.
> >> Yes, it seems very likely this is due to proj missing. Check that
> >> proj.dll is available in one of the paths in the PATH.
> >>> Thanks,
> >>> Brendan
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> Spatialys - Geospatial professional services http://www.spatialys.com
> Is GDAL_DATA set? I seem to remember that error if it was missing.
> Just a guess though...
> kss
> Kyle
