[gdal-dev] reading postgis xyzm with ogr2ogr
Rémi Cura remi.cura at gmail.com
Thu Feb 12 01:49:57 PST 2015
depending on how desperate you are you could :
 - use simple COPY statement to export you LINESTRINGZM from database
 - use python + python-ogr and manually create a X Y Z M file
 - use python + shapely
In all case you can wrap it into a command line executable, liek ogr2ogr.
Cheers,
Rémi-C
2015-02-11 19:23 GMT+01:00 Duarte Carreira <dncarreira at gmail.com>:
> Thanks Paul.
> Yes, but I'm trying to export all tables from a schema, so I don't state
> the names of the tables. I think using sql would require 1 comand per
> table, right?
> So my command is something like this:
> ogr2ogr -progress PG:"dbname='postgis'
> active_schema=schema1 schemas=schema1 <connectioninfo>" -f "SQLite"
> mydb.sqlite   ....
> I was hoping for a magic parameter to avoid the xyzm error...
> On Wed, Feb 11, 2015 at 5:55 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> You could use the OGR sql query option to wrap your geometry call in a
>> force2d or force3d function call in PostGIS?
>> Paul Ramsey
>> http://cleverelephant.ca
>> http://postgis.net
>> On February 11, 2015 at 9:54:07 AM, Duarte Carreira (dncarreira at gmail.com)
>> wrote:
>>  Hi there.
>> I’m trying to figure out how to read xyzm geometries from postgis with
>> ogr2ogr, if at all possible.
>> I get the usual "is not supported" error:
>> ERROR 1: Reading EWKB with 4-dimensional coordinates (XYZM) is not
>> supported
>> But reading old tickets I get the idea there is a way to read and just
>> ignore the 4th dimension, instead of getting null geometries.
>> For instance:
>> http://trac.osgeo.org/gdal/ticket/1323
>> From 8 years ago(!), says:
>> The problem does not occur if a layer is accessed using
>> OGRPGDataSource::GetLayerByname()
>> Then, geometry is read in EWKT form and parsed correctly without any
>> errors but M coordinate is omitted.
>> Can this be done using og2ogr?
>> Thanks,
>> Duarte
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150212/4b30c5df/attachment.html>
