[gdal-dev] new to gdal, converting projection, need some help
Andrew Simpson
simpsonar77 at gmail.com
Thu Feb 12 04:58:30 PST 2015
I'm new to learning GDAL (mapping in general). I have a bunch of tif files
(300+) that are in NAD83, but my mapping application only uses WGS84. The
tiles are all around 50-75Mb each
I'm able to use gdal warp to convert the projection properly to WGS84, but
the images (tiles) come out skewed.
I tried using bdalbuildvrt first to create the vrt, then gdalwarp with the
following options: -co TILED=YES -co BIGTIFF=YES -of GTIFF -t_srs
"+proj=longlat +datum=WGS84 + no_defs" input.vrt output.vrt
Ok, so this mostly works, but I have 2 questions/issues:
1. what is the best way to convert the projection and eliminate the
skewing?
2. The single .tif produced is now >30GB! significantly larger. why does
this occur and how can I keep this file size down?
Thanks for any info!
Andrew Simpson
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150212/4663389a/attachment.html>
