[gdal-dev] VRT creation from Python, adding existing geotiff as bands
Rémi Cura remi.cura at gmail.com
Mon Feb 16 08:23:49 PST 2015
Thank for the fast answers !
@EvenRouault  : thanks for the snippet, I wasn't aware of this mechanism to
transmit option trough python dictionary.
It should most likely be sufficient for my needs, even if I don't
understand it fully yet.
I had read the tutorial but failed to translate it from C++ to python.
I'm still _very_ reticent to create XML for VRT in python, I don't see how
it could be safe and age well.
@Anton :
thanks for the lib, I'll look into vrt.py
<https://github.com/nansencenter/nansat/blob/master/nansat/vrt.py> to try
to understand how to add an existing tiff file as a band to vrt.
I don't think I need "SourceTransferType", because the type of the vrt band
will be the same as the type of the existing geotiff file.
Cheers,
Rémi-C
2015-02-16 15:11 GMT+01:00 Anton Korosov <anton.korosov at nersc.no>:
> Dear Rémi,
> you may want to look at our Python package NANSAT (https://github.com/
> nansencenter/nansat) which we build around the GDAL and especially VRT.
> We even have a separate class VRT() for creating, changing and using VRT
> files.
> More specific regarding your question, you can try to use the
> SourceTransferType parameter of the VRT. Search for this keyword at
> http://gdal.org/gdal_vrttut.html
> Regards!
> Anton
> On 16/02/15 14:13, Rémi Cura wrote:
>> Hey dear list,
>> this is my first post here,
>> so sorry if I'm asking something obvious.
>> (I noticed the 2 previous mail thread regarding python and VRT).
>> I wrote python functions to convert a numpy structured array to several
>> gdal rasters.
>> A numpy structured array is a 2D pixel array, but each pixel has in fact
>> several values of possibly different type (like band).
>> For instance a pixel dtype can be [float32,uint16,Float64].
>> I want to convert this array to raster(s).
>> First I tried to create one raster with several bands,
>> but GeoTiff cannot handle bands with different pixel type (or I didn't
>> find how).
>> I concluded that I must create several rasters, and put them all as
>> bands in a VRT.
>> So far I have been able to create several geoTiff raster of various type
>> corresponding to the numpy structured array.
>> Now, I don't know how to create from python the VRT that unites all this
>> rasters.
>> When I try to write in a VRT raster band I get errors.
>> I am well aware that I could create the XML directly from python, but it
>> feels like a pretty bad architecture idea.
>> Anybody knows how to do this /and/or has comments about this task?
>> Many Thanks,
>> Rémi-C
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150216/e03dbc90/attachment.html>
